Ok, I have a E6420 Core 2 Duo w/ 4 MB of cache. I currently have it overclocked to 3.5 ghz @ 1.425v. I would like to go higher, but only if I can be sure it can be used on a PC that is up and running usually 24/7. I dont want to go super high in the voltage department, and was currious what would be a safe voltage for every day use? Obviously Ive already made it from 2.13ghz to 3.5 ghz, so thats nothing to be ashamed about, but the 3.7ghz+ territory looks really good
But I only want to proceed to a clock speed like that if I can run the PC 2/47 that way, and at a safe voltage.
I guess my questions are as follows:
1.) whats a safe voltage for a core 2 duo as far as overclocking with aftermarket cooling to be used on a mostly 24/7 basis?
2.) is it OK to overclock the processor to the limit of the FSB, but leave the memory locked @ 900 mhz?
3.) HT multiplier that starts at 5x, should this be reduced as you overclock, and if so at what FSB should it be reduced to 4x, 3x, 2x?
4.) I have corsair DDR-2 800mhz XMS2 6400 C4 4-4-4-12 memory and currently have it at the clocks above @ 2.1 volts. I was currious if anyone had any results overclocking this memory in the past, and if so about what the limits would be on 2.1v and the 4-5-5-12 clocks?
sorry if this is full of run on sentances and makes little sense. I would be happy to clarify anything if needed, hopefully its understandable. IM at work so typing this up kinda fast
