core 2 duo or core 2 quad for my setup...
AZBOOSTIN
Hey guys trying to stay on somewhat of a budget... Right now I have
Asus p5n32-e sli board
2x 8800gts 512
4 gig ddr 800..... vista 64
right now im using my old p4 3 ghz single core chip and it sucks for gaming.....
anyways Would I see any gain going to a q6600 quad core? or should I just get a duel core for now..... I minaly play wow. but I do play gears of war and alittle crysis...
My plan if I get the quad is the 6600 so if thats not needed can you guys recomend a dual core chip that will suit my needs...
Well if your main thing that you do is gaming, then just stick with the Core 2 Duo. An E8400 or something would do you well and I think they cost about the same as a Q6600. It'll run cooler and you can probably overclock it higher for that reason (but if you don't want to overclock... then it'll have a much higher clock rate anyways).
Games don't often benefit from a quad core although that may change before too long.
i went from a q6600 to an e8400 and noticed a little better gaming performance and MUCH lower temps. only thing that sucks is the much longer encoding times when burning a dvd.
E8400 should get you at least 3.8GHz with good cooling. Lots of people get 4GHz +
E7200/7300 should get you at least 3.5GHz with good cooling. I see lots of posts where people can't get 4GHz with them
hmm.... I have heard 3.6 is ez with the q600 what would make the e8400 a better choice?
I've read that alot of q6600's can't even make 3.6 ghz. I've also read that gaming performance doesn't change a whole lot above 3.0 ghz. At that point you'll most likely be held back by the gpu anyways. Of course you're already at 3 ghz with your current chip so I could be wrong.
I'll be getting a q6600 for the encoding benefit since it will still run games well at 3.2-3.6 ghz.
