Crazylikeafox
- Aug 2, 2006
Is there a cord that makes those hardcore red/black cables and converts them to a regular cable plug for my pc?
No, I mean the wires that come from a speaker that are like just open copper, and you put them into a clip thing which is on the main component of your stereo.http://www.monoprice.com/products/p...d=10218&cs_id=1021804&p_id=666&seq=1&format=2
Is that what you're looking for, or are you talking about speaker wire?
Are you talking about the clips on the back of a speaker for the speaker wire and then trying to plug that directly into your pc? So it would be Pc connection to speaker? I don't think youll find anything like and if you did I doubt your sound card would drive the speakers very well.
So basically, you are out of luck. I've never heard of a speaker wire to 1/8th stereo miniplug solution.
OOOOoohhhh! i have, its called an "amplifier". It takes your 1/8th stereo (or more likely RCA) inputs, and converts them to speaker wire!
See also "Receiver"
(although, goofily enough, my klipsch promedia speakers use precisely such a cable from the satellites to the sub. bare wire connection to the sub which has the amplifier and headphone style jacks on the satellites).
what speakers do you own and how much are you looking to spend?So do you guys know any specific models i could get?![]()
