TechStuey05
- Aug 5, 2005
Hi, I have a Windows Vista computer and a western digital 2 TB USB External Hard Drive. I have about 160gb of data that I want to copy to my External Hard Drive. When I begin pasting the files to the external drive I get the spinning wheel and it doesn't go away, the spinning wheel only appears when I place my cursor over the folder of the external drive, after that I also can't close the folder without windows explorer restarting.
Also it shows the wrong progress time of how long before all the files are copied. It usually starts off about right when I first begin copying the files to the external but then it gives the wrong amount of time and it stops progressing.
Should I just leave it and let it copy all the files? Is it safe to do that? I also re-formated (quick format) the external drive as NTFS just incase there were some issues on the external drive but there was no change.
Is my external hard drive defective or is it my computer causing the issue? I just purchased it from Newegg a few days ago. Please help
