What is the best app for moving DVD's to hard drive storage. I want full quality. Storage space is not an issue. I just want to end up with a single file of the movie that can be streamed to an XBox.
your single file requirment is going to be the bane of your existence then.
Can I get more explanation on this. I am looking into to do the same thing, full quality, sound, etc., and am not worried about space. If a single file is not possible or to much a hassle, then can a folder with a single play file be possible with all the files needed with zero compression?
With DVDFabDecrypter you have the option of ripping only the main movie file, and the audio file of your choice (ie, DD/DTS or MP3), to your hard drive. The ripping process only takes a few minutes, and leaves a VOB file. The single file (the video-TS file) is the only file that needs to be saved; and can be played directly using the VLC media player without any further conversion. Movie playback is transparent to the DVD playback from the original disc. If you want, you can later convert to Xvid via AutoGK for transfering to a PVP.
No need to keep DVD movie discs aroung anymore. When I buy a DVD movie, I never play it from the disc or even keep it; I ripp it to my hard drive, and give the disc to a friend.
By 'Xbox' do you mean a 360 or an original with XBMC?
I could be wrong, but I was under the impression that XBMC could stream DVD .iso's.
