If you know the specific file you need to copy you could create a batch file to do this with many of the mentioned products..Is there any software that can copy a spesific file listed in text file and it works on Windows 7?
http://www.xxcopy.com/xxcopy25.htm
After you figure out the command line just put the exact command you would type on the command line in a file and give it a .bat extension.
This is just one example. I know robocopy and several of the others support passing arguments via the command line as well.
FOR /F "usebackq delims==" %%i IN (c:\users\jdrescher\test.txt) DO @ECHO %%i
