Copy C (boot drive) to USB Drive?
Ashton
My Desktop has 2 SATA ports (yes it sucks, I plan on buying a PCI sata controller but right now I have all PCI slots in use) One of these is my 160gb "C" drive.
First I purchased a 1tb drive and added it. When it filled up I purchased a 2TB drive.
So I now have 3 drives and 2 ports, so one has to go to USB. Because the boot drive is C I chose to put the 1TB on USB and move all my most-used files to the new 2TB
I want to copy my C drive (Win 7) onto the 1TB drive so I can bump my internal storage from 2.16 TB upto 3TB.
What's the best method of doing this? (I'd really prefer not to have to repartition either drive)
So the 1TB drive is now empty (or at least all of its content is now on the 2TB drive)?
If so, you could connect the 160GB and 1TB drive to your SATA ports and use the Easeus Disk Copy bootable CD to copy the contents of the 160GB to the 1TB. The 1TB will then become bootable with your OS installation on it, though you may have to extend the partition to expand the entire 1TB since I believe it'll initially be the same size as the other (160GB) with the rest of the space showing as unallocated.
Easy enough to do, though.
There are several programs that will accomplish everything I described, but I've personally used that Easeus freeware to accomplish this one someone else's computer and it worked perfectly.
