sethiano
- Jul 3, 2014
Hi guys,
Sorry if this has been posted somewhere else, but I am buying a full loop.
Here is what I am going for:
From what I gathered, I will be running brass\copper\nickel\silver - I know I should stay away from Aluminum, which I have.
Do I need to be running any special coolant that prevents corrosion? I am running UV tubing so clear coolant would be best. Any suggestions would be awesome!
Fittings -
http://www.performance-pcs.com/alph...evolvable-g1-4-deep-black.html#Specifications - brass chromatized
http://www.performance-pcs.com/fitt...ing-g-1-4-thread-id3-8-od5-8-matte-black.html - doesnt say ( but the other matching enzotech's below are matt plated brass so I am assuming it's the same
http://www.performance-pcs.com/enzo...for-3-8-id-and-5-8-od-tubing-matte-black.html - matte plated brass
Rads -
http://www.amazon.com/Alphacool-NexXxoS-Copper-240mm-Radiator/dp/B007P05XL4 - full copper
cpu block
http://www.performance-pcs.com/ek-supremacy-evo-cpu-water-block-copper-acetal.html - copper
gpu block -
http://www.performance-pcs.com/ek-fc980-gtx-wf3-acetal-nickel.html - nickel plated copper
res -
http://www.performance-pcs.com/new-monsoon-series-two-d5-premium-dual-5-25-reservoir-red.html - this has silver biocide plugs
pump -
http://www.performance-pcs.com/swif...5-pump-module-pwm-enabled-single-version.html
Thanks in advance!!!
Seth
Fittings -
Rads -
cpu block
gpu block -
res -
pump -
Seth
