So I'm doing a case mod project with a new Lian Li Cube case. To avoid condensation on the cpu I've decided to make a resivoir out of copper. Placing pelters on the bottom of it to cool the copper res.
Left side view from front
My plans, noob drawing, but you can get the point
does copper transfer heat better if its thicker?
if I placed maybe 4-5 fins from the bottom halfway up the res would that help cool the overall temp of the liquid passing through the res.
The res will contain about 2000ml of liquid in it as the dimensions are 5x"5"x5"
