ronenvelarde said:They dont have angle bar in copper. I am going to call them this morning and check maybe they just dont list it on their site.
motithejrt said:Isn't copper conductive? The first thought that came to mind was a short of some sort.
ronenvelarde said:What if i use square tubing for the frame? Cut notches and then braze?
"turns either green or other dark unslightly colors over time"
Eww how can I stop this from happening? Any type of coatings I can use? Can copper be anodized?....
Invest in a metal brake, use copper sheet and bend your own angle material.ronenvelarde said:They dont have angle bar in copper. I am going to call them this morning and check maybe they just dont list it on their site.
ronenvelarde said:Could I use silver solder for joining up aluminum to copper? I have a little brick area that I used for melting glass for my ceramics class. Its square and has soft brick so it will work perfect for copper. Which type of silver solder would anyone recommend? I was going to use this stuff
http://www.bernzomatic.com/bernzoma...?attributeId=BMBZOPA000007&productId=BM097182
any cons?
