Cooltek Antiphon questions
Iserlohn
Anyone have this case?
I'd like to know how much room (in cm or inches) there is between the mainboard tray and side cover to tuck cables away. It is a rather slim case, so it can't be much.
Also, I'd like to put two 3.5" harddrive trayless swap stations in the bottom two 5.25" spots. When loaded with harddrives there should be a little bit of moving are to avoid the heat getting trapped there. Is there some air movement in this spot in the case? Because I can't see how I could somehow direct a fan airflow there.
Thanks!
