Coollaboratory Liquid Pro Thermal Compound
Soldier
Has anyone ever tried this stuff?
[FONT=Arial, Helvetica]Coollaboratory Liquid Pro Thermal Compound
[/FONT]
From the way the information portrays its product, its as if its compound is made up of something entirely different then Arctic Silver 5.
the compounding liquid says its made up of: [FONT=Arial, Helvetica][SIZE=-1]100% liquid metal alloy
so, what is everyones take on this? ( Just came across it and thought I would ask )
ps.
since this deals with cooling of some type ( cpu cooling/contact grease/liquid and compounds ) thought I should post it here..
[/SIZE][/FONT]
It's supposed to be really good. BUT, it has draw backs. such as (1) it conducts electricity. Also (2) you can not use it on aluminum heatsinks or it will eat the heatsink, the compound has gallium. Examples:
http://bogieworks.blogs.com/photos/uncategorized/aluminumrust.jpg
http://sci-toys.com/scitoys/scitoys/thermo/liquid_metal/liquid_metal.html
COPPER HEATSINKS ONLY
Another disadvantage of this product (3) is that it is extremely hard to spread. It acts physically like mercury. Think about it as if you are trying to spread water on an oily surface. All you will end up with are lil circles of water.
Finally (4) it's liquid. There have been reports of this stuff seeping out from between the CPU and heatsink and getting on to the motherboard. In other words, it doesn't stay still.
As you can see, these disadvantages can drive a customer away from this product. I personally would recommend the AS MX-1 over the AS5. It has about 1 degree C advantage over the AS5 and it is non conductive. Just my 2 cents ;)
It's definitely not a bad TIM.
I've tried it and I like it, but I found it really hard to apply properly... It beads around on the IHS of the CPU and doesn't stick like the instructions say it will. Temperatures were 2-3c lower than a cured AS5 application. I removed it almost immediately though, as it beaded at the bottom of the CPU when the board was turned on it's side (read: installed in the case)
I've personally used a gallium/indium combination as a TIM for fun when I started watercooling. It's a molten metal (melts at -20c) that really got my temperatures low. A good 5c off of AS5 as I was able to paint on an impossibly thin layer.
No molten metal TIM should come into contact with ANYTHING aluminum. Period.
