Coolit NV200 kit anywhere?
notalent420
I'm looking at watercooling my new upcoming build and already have my sights set on the Freezone Elite for cooling the CPU.
I also wanted to look into watercooling my GTX 260 since I live in hot Hawaii. Right now my 260 is idling at 50C with the fan speed at 40 (auto). And this is only winter. Usually in the summer the room temp can reach 90F.
So I was doing some searching and found that Coolit also had a dual bay VGA cooler for the GTX2xx series. I found links to them for sale at stores online but they are all out of stock. Also the Coolit website doesn't mention it at all.
I was wondering if this is still on the market or did it get discontinued? Seems kinda odd that a product for a current product would leave the market within 6 months.
In any case, is there any other similar method for cooling the GPU? I may get another 260 for SLI so whatever I get would have to have 2 coolers.
Thanks in advance
Not a bad price... But Blegh. I can't see that thing putting out good temps - and I also can't imagine how much wattage it would suck down to cool 2 GTX260's with TECs...
I get your point but it is a very simple solution and one that works well. The OP is probably seeking a simple solution. I installed this kit for a friend a few weeks back and I must say that the results are quite impressive. She has 2x260's and the OC's are outstanding.
It's not my cup of tea, but for the price and no hassle, it is a really good product. Just mt 2 cents.
I have a factory overclocked 260 and plan on adding another one and possibly OC to at least 700MHz. Factory overclock is already at 666MHz so 700 seems reachable.
