Looks pretty good if they get the price down.
http://www.extrememhz.com/freezone-p1.shtml
http://www.coolitsystems.com/index.php#
QFT... i bet if they had those in retail stores kids would buy them 24/7xSnowmaNx said:omfg a beverage chiller thats leet.
dude.......when you are cooling the hot side of a pelt, you are dealing with all of the heat that the pelt is pumping in addition to a large amount of waste heat from the pelt itself. adding a pelt into the equation means that you need a whole lot more cooling, not less.revenant said:PS: with the chiller part, it should not need a bigger fan.. it's cooling the water with the thermoelectric process more than anything.. then the fan cools the back of the peltier.. I reckon.![]()
i made a beverage chilled with a damaged 80 watt pelt a while back.......it was good for shits and giggles, but a pelt bevy chiller isn't all that usefull. the biggest problem is getting reasonable heat exchange between the can/bottle and the pelt. the bottom just isn't enough to do anything. i used a chilled salt water bath for mine.jcll2002 said:QFT... i bet if they had those in retail stores kids would buy them 24/7
DFI Daishi said:dude.......when you are cooling the hot side of a pelt, you are dealing with all of the heat that the pelt is pumping in addition to a large amount of waste heat from the pelt itself. adding a pelt into the equation means that you need a whole lot more cooling, not less.
spreading a given amount of airflow over a larger area results in improved fan performance as a result of reduced back pressure. the fan is able to move more air as a result of it being able to maintain closer to it's spec'd revolutions and optimal flow conditions. shrouds deal with the larger dead spot in the center of the fan more effectively than moving to a smaller fan does.revenant said:PS: 120mm fans aren't always better, unless you get powerful ones.. they spread the air flow over a larger area, and have a larger dead air section in the middle.. I swapped all my 120s out for 80s for my extra video card cooling because of that.. gah! ok - back to work.
the cranium doesn't have to be large, just hard as rock.revenant said:you just have to shoot everyone down with your large cranium, dontcha.
ExtremeMhz said:There is a potentiometer in the upper center part of the included PCB Thermal Control Module labeled RV1. ...snip... Now, at first, I was accidentally turning it the wrong direction. This is because of the way I had positioned the control module on the case. Just make sure the CoolIT name is on the upper left hand corner of the PCB.
