Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
i saw a bunch in there for $130+$20 shipping...what do you guys think?probably much cheaper with the best offer option..Thanks...it is much cheaper on h120 compact from swiftech i dont know how it is compared to swiftech 120 compact..thanks..
i used one for a customer build, VERY good cooler
just make sure you swap the fan(loud).. and have the room for it, It will conflict with tall northbridge coolers
