In my quest to get some better performance out of my WC setup, I've been looking at waterchillers. Most are too loud, bulky, and/or troublesome to install. I don't like TEC/water setups becase of the failer, condensation and power usage issues.
However, I've been thinking about Eliminator or Freezone from CoolIT. They use TECs to chill the water and a heatsink/fan combo to cool the TEC. Power usage seems reasonable @ 50 wattish. I have a dual rail PSU for sli and I don't plan on sli-ing anyway.
So would a $186 Eliminator work well in an existing WC loop (I plan on taking out the built in CPU block)? Right now I have
T-line -> MCP655-> MCW60(OCed 8800GTS) -> DD 480GTX -> Apogee(E6600@3.6) -> back to Pump
My plan
T-line -> MCP655-> MCW60(OCed 8800GTS) -> DD 480GTX -> Eliminator ->Apogee(E6600@3.6) -> back
Pros
1. Chilled water to CPU (going to upgrade to quad soon) and semi chilled to GPU
2. Not going down below ambient (hopefully... I'll have to double check after installing)
3. Extra pump and no worry about failing TEC overheating CPU/GPU
4. Won't be taxing the TECs too much since loop's water will be cooled by the DD 480GTX as well
Cons
1. Shell out more money
What do you guys think? Will this be more effective?
My plan
Pros
Cons
