Jun 2, 2011 #1 B bcham Limp Gawd Joined Mar 23, 2007 Messages 153 just installed and getting very high temps.50% idle.here is a pic of my fan speed,are these to low,
Jun 2, 2011 #2 C Cruiza [H]ard|Gawd Joined Mar 17, 2008 Messages 1,701 Do you mean 50C idle? That does seem kind of high, but what are your load temps?
Jun 2, 2011 #4 C Cruiza [H]ard|Gawd Joined Mar 17, 2008 Messages 1,701 Again, do you mean 66C? If so, then that is perfectly acceptable.
Jun 2, 2011 #5 B Betauser 2[H]4U 2FA Joined Jul 14, 2003 Messages 3,872 I think his keyboard doesnt recognize the celsius What cpu do you have?
Jun 3, 2011 #6 M micron Limp Gawd Joined Jun 13, 2004 Messages 193 Make sure you have the block seated correctly, it took me a couple of times to get it right. Also, if you have the block/pump plugged into a variable speed header, make sure it's running full blast.
