Riptide_NVN
- Mar 1, 2005
Recently I got a VF700 and it is not silent, makes some bearing noise that is bothering me. It's not horrible but I can still plainly hear it with the case closed. My previous VF700 (on X850 right now) is not doing this so I know I got a bad unit. I want to try something else.
I would like to get a Panaflo Hydro Bearing 120mm fan and use this bracket here to mount it right next to my X1800XT.
http://www.pccasegear.com/prod2922.htm
Do you guys think this will move enough air over the Zalman heat sink to keep the card cool enough that I can just leave the Zalman's fan turned off?
