Hi Guys,
After having a look through the forum the other day for the first time I saw that there was quite some expertise around modding and cooling, etc on this forum so decided to join
I just bought myself a new case but it has no PSU, cooling system, mobo or anything. This is the case:
Thermaltake Kandalf VA9000SWA series :
Link: http://www.thermaltake.com/xasercase/kandalf/swa/va9000swa.htm
Now what i'm planning to do with the case is use it quite intensively and use it as a 'pretty storage' system also. But I am not sure what PSU and cooling I will need. Preferably as quiet/noiseless as possible.
The comp will need to be able to handle 10+ HDD's (in the long term at least), an Intel P4 3,x processor, and a relatively powerful graphics card (no cd drives, floppies, or anything else). Just those.
For the PSU I was thinking of the Thermaltake Fanless PSU Series (W0029, W0050) :
Link: http://www.thermaltake.com/purepower/menu.htm
That should be enough no? 350W? A HDD needs about 12-13W no? so when doing the maths for 10-12 hdd's this should be no problem right..or is this just in theory? Adding to that only a processor, graphics card and some ram that should be fine yea?
HDDs specs would be 400gb seagate or hitachi drives and 500gb+ drives which will come out later (I'm planning to add more hdd's as time goes on).
Moving on from the power consumption to the cooling...even though the cooling unit above alone is quite good I've heard..will it be enough to cool down so many hdd's? If not I was thinking of adding a liquid cooled unit:
BigWater- 12cm Liquid Cooling System :
Link: http://www.thermaltake.com/watercooling/cl-w0005bigwater/cl-w0005.htm
Oh and from what I've seen in pictures, there are 2 'liquid pipes' coming out of the cooling unit yea? Is it possible to split this into 20+ channels, lets say if I want to cool down the CPU with this..and also each of the HD's using one of these Koolance HD coolers:
Koolance HD-50-L06 (HD) :
Link: http://www.koolance.com/shop/product_info.php?products_id=177
Btw...which mobo would you guys recommend for this, specs/requirements for the mobo:
Specs/requirements:
* relatively cheap
* needs SATA controller - to be able to accomodate 10+ hdd's in the LT
* designed for an Intel processor (except Celeron) and being able to accomodate faster, better processors in the future
* needs PCI express or some fast slot to be able to accomodate a video card for DV-in DV-out <-- not sure if that has to be taken into consideration to get a mobo but just in case it does
* that the FSB of the RAM/CPU is also relatively high to be able to accomodate future 1066mhz+ RAM modules/processors
* and of course the standard USB 2.0 / Firewire, etc.
Thanks already for reading this post and for any help, even if its just to answer one of my questions
Thermal
Specs/requirements:
* relatively cheap
Thermal
