Cooling Solution for X1950xt
3erious
Those cards do heat up nasty. With good active cooling applied the accelero would probably be better, though the Vortex exhausts out the case which will lower the overall temperature of the case.
Personally I've seen good results with the accellero...I would also grab some heat spreaders for the chips on the card. That area also get's quite hot.
