Cooling question
locutus24
So i ran out of options on cooling my Athlon XP 2500+, cause my case fans were doing nothing. My question is, can mobos be damaged by dust cause right now im using a house fan as my cooling solution. I know that thing is going to push alot of crap through, so will my mobo be damaged or should i just dust it out more often
Thank you for anything on this matter
dust just gets in the way and causes heating problems, dust itself doesn't do actual damage or else we'd all have to have our rigs in vaccum sealed chambers or something ;)
Ok now i am less stressed, cause w/o it my cpu heats up to 60 degrees C sometimes :eek:
