NoVFishbulb
- Jun 20, 2009
Heya everyone! Hows it goin? ^_^
I was referred to this community by a good friend of mine when I told him about a problem I was having, and I must say, it's a pretty awesome place
Hopefully yousguyses can give me a hand!
Basically, I've been having some really annoying cooling problems with my Q6600.. Which is weird, because its a really cool-running cpu! I know its not the CPU though, because I DID have it running at acceptable temperatures before. Before the problem REALLY started, I had idle temperatures around 35-38 degrees, and load temperatures in the high 40's. Those numbers weren't TOO bad, but I have friends that have idle temps in the low 20's (two other factors play into that: Bigger cases with better airflow compared to mine, and cooler rooms. It can get warm in here) so I wanted to drop my temperatures a few degrees. For a thermal interface material, I was using the gunk that came on the bottom of the stock heatsink, so I assumed that to be the culprit.
My solution? take the heatsink off, clean off the goo with some isopropyl alcohol, and remount with some thermal paste.. and thats what I did! Unfortunately, all I had was some crappy old silicon white goo thermal paste. I lost my tube of arctic silver, so thats all I had to use.. I figured, hey, it would at least be a few degrees cooler than what I had before.. BOY WAS I WRONG.
My temperatures after the change were massive. By remounting the heatsink a few times and using a little bit less thermal paste (I kind of used the AS5 thin line technique; but I used a lil' bit more because of this paste's lower viscosity.) I managed to lower the temps by a couple of degrees since then, but I'm still sitting at a stomach-churning ~48 idle and 60+ under load.
I've remounted the heatsink a bunch of times.. I'm next to positive that I'm mounting the heatsink properly (I could definitely see that I had proper contact because the thermal paste spread well.) so I don't think that's the problem..
Every time I remounted, i wiped the old thermal paste off of both my heatsink and CPU and used rubbing alcohol as a solvent to clean any residue that was left. I tried all sorts of different techniques, all with the same effect. I tried a rice-grain amount in the middle, a thin-line laterally, I tried the old smearing on the heatsink with plastic wrap thing.. None of it worked. I think my technique is okay.. I've done it many times before!
So by my logic: It's not ME thats the problem; heatsink is mounted properly, I think my thermal paste technique is okay.. What else could it be?
well..
a) Crappy thermal paste. It was old and stale. I DID mix it up very thoroughly by squeezing it into a clean plastic bag and squishing it around.. It didnt have much effect. Does old white silicon thermal paste get unusable after a certain amount of time? That's my best guess.
b) messed up heat sensors. I don't think this is the problem because it seemed okay before.. Temperatures fluctuate in a very natural way.. hrm
c) help me with C?
lol, thanks in advance for any help you can give me guys. ^_^
My other specs for reference:
Q6600 at stock speed, stock cooling! turrible temperatures.
ASUS P5N-E SLI mobo
4gb 800MHz DDR2
nVidia 9800GTX+
600W Thermaltake PSU
and I've been using Core Temp to monitor my temperatures. I know that readings from different software can vary greatly, but more temperature information might just confuse me further
EDIT: One more thing to note.. I do have the G0 stepping of the Q6600 and I'm seeing a temperature difference of 3-5 degrees between cores 0 and 1, and cores 2 and 3.
well..
c) help me with C?
ASUS P5N-E SLI mobo
4gb 800MHz DDR2
nVidia 9800GTX+
