Cooling pad for MacBook Pro i9
Discussion in 'Apple Products' started by chiu, Aug 5, 2018.
  1. chiu
    chiu Limp Gawd
    325
    Sep 14, 2011
    Can anyone recommend a cooling pad for MacBook Pro i9 so that I can improve its CPU performance?
    TC
  2. BiH115
    BiH115 Gif Guy
    8,883
    May 12, 2011
    Trolling, or? I've got the i9 15" and post patch I've had zero issues with throttling, and never really had any with general warmth. What exactly are you doing with it?
  3. chiu
    chiu Limp Gawd
    325
    Sep 14, 2011
    I want to push the CPU to 4.8GHz (sustainable) if possible. Any cooling solution that can push all six cores to 4.0GHz or above will be great.
  4. robvas
    robvas Gawd
    605
    Jun 30, 2011
    A cooling pad won't help you in any way.
  5. vegeta535
    vegeta535 2[H]4U
    2,593
    Jul 19, 2013
    Get a PC that has proper cooling to reach that. Even then it is still difficult in laptop form factor.
  6. chiu
    chiu Limp Gawd
    325
    Sep 14, 2011
    Any other solution?
  7. pendragon1
    pendragon1 [H]ardForum Junkie
    10,624
    Oct 7, 2000
    lol oc a i9 MacBook?! get a intel based tower, oc it and put osx on it if you want/need that speed. I dont know of any pc based laptops that can do that.
  8. chiu
    chiu Limp Gawd
    325
    Sep 14, 2011
    This guy can:
    But need a more elegant solution.
  9. UnknownSouljer
    UnknownSouljer [H]ardness Supreme
    5,713
    Sep 24, 2001
    He's not interested in overclocking it. He just wants to maintain the turbo boost speed (4.8GHz), which also as I understand (regardless of platform) isn't sustainable.
  10. chiu
    chiu Limp Gawd
    325
    Sep 14, 2011
