I could use some advice on whether to go with a cheap watercooling kit of just stick with a HSF combo.
I want to overclock to fairly high speeds on my new chip, while keeping the sound down. I also do not want to spend over 100$ on CPU cooling.
I was looking for lowcost water cooling kits to cool the cpu, i came up with this:
CoolerMaster Aquagate Mini R80 Assembled Water Cooling Kit
http://www.frozencpu.com/ex-wat-68.html
Versus a HSF combo like this: Thermalright XP-90C http://www.frozencpu.com/cpu-tri-22.html or Zalman CNPS9500 http://www.frozencpu.com/cpu-zal-19.html
I also wondered if it was possible to assemble a water setup for under a 100$ resevoir, pump, radiator, and block. Though im not even sure a resevoir is nesc.
