Cooling options for 8800 GTS
c_loke
Hey all,
I just wanted your opinions on coolers for my EVGA 8800 GTS Superclocked 320mb (G80). I've looked at a few of them and noticed that there are a lot of compatibility issues with my card. What kind of cooler would you reccommend for me that wont chew up to much of my pci slots. I looked at the Arctic Cooling Accelero Xtreme 8800 VGA Cooler, but I am worried that it is too big since I need all the PCI slots I can get.
Also, is the stock cooler any good. If I replaced the paste with AS5 for the GPU, what would I replace the ramsink pads with if I decide to put it back on?
Thanks.
Accelero S1 Rev. 2 if you can find one, it was pretty much made for the G80 boards like yours. Assuming you have the proper case fan configuration (enough exhaust pressure) you can even run it passively with results that are still far better than the stock cooler.
