Cooling my HTPC
notarat
I've been using my Asus AT5IONT-I for a few weeks now and, after recovering from a crashed hard drive, I decided I'd make an attempt to cool it a bit better.
Temps before my mods were in the high 40s C on the CPU to low 50s C on the GPU, and those results are measured in a room that never exceeds 74°F.
I pulled the system out of the NXT Rogue case I had it in, and placed it into a Thermaltake V4 mini-tower.
Then I made a few mods to the TT Case to increase cooling.
First up, I cut out part of the front case grille that was in front of the hard drive cage so that there was less restriction of cooling air. Yeah, it's a gnarly job but the only thing I had handy was a pair of wire cutters
I then installed one of those 3-speed Antec fans that came included with the Antec P-180 case.
I set it to medium speed and it is cooling the hard drives.
Temps are >12°C cooler now so I feel satisfied it was a good change
My second mod was to take the plastic fan holder from the P-180 that sits in front of the HDD Cage and use it to mount a cooling fan for the CPU and GPU.
I drilled small holes in the portion that the arrow is touching, and I mounted the fan that was included with the Thermaltake case pointed it down to cool the CPU/GPU.
Temps are WAYYYY lower now, as in 20°C cooler
Given the temperature drops, I think I may overclock this little puppy a bit.
My motherboard only gives a few basic overclocking settings so the best I was able to get without upping voltage was a 150MHz overclock.
Any more than 215 on the bus fails to boot so I set it back to stock 1800MHz
I didn't really notice any difference in performance between 1950 and 1800 so I'm just going to leave it stock for now.
My god!! Shrink those pictures down and then maybe people will care.
Maybe we can help when you post smaller pictures but I'm concerned that you solved your problem the hardest way possible.
Why is this overclocked? Is it an HTPC? O/c will run temps up fast and HTPC's don't frequently need this.
With some pictures of the machine that are a bit smaller as well as more info on your build could yield better info. That machine seems a little warm but not impossible.
There's a lot that can be done with fan arrangements, better coolers and inside cleanup that can be a bit more elegant than taking a chainsaw to the case....
