Cooling for Shuttle SP35p2 PRO
TgStylez
Hi guys,
I'm about to build my new gaming rig I have purchased a shuttle sp35p2 pro case.
Just wanted to know what is the best quality heatsink and fan for the CPU, that isn't too loud but has decent cooling performance.
i don't know if you realized it, but it comes with a CPU HS/F (actually more like 2 fans on 1 heatsink). I wouldn't recommend using an aftermarket heatsink. I doubt any would fit, the mounting holes are not in the standard locations and there isn't much space for a standard HS either. the stock heatsink is more than adequate though, it is a pretty smart design.
you might be interested in some of the fan mods out there. the most common one is to reverse the orientation of the ICE fans. another would be to replace the 70mm fan with an 80mm fan (in addition to reversing the orientation).
