Cooling for my FX5200
First of all: Yes. I know it's a crappy card. :p
Now that that's out of the way. This is the video card I'm
stuck with for the time being (had to sell my 6600GT AGP card
to pay some bills :( ).
Anyway, it's an XFX Geforce FX 5200 128MB card:
http://www.xfxforce.com/product_view.php?sku=PVT34KNT
You can see bigger pictures here:
http://www.chiefvalue.com/app/productdetails.asp?submit=property&item=14-150-041
I used coolbits and nvidia's "auto" overclocking/detect thing
and it brought my speeds from 250/333 to 310/456.
I was pretty impressed with that since there's just a heatsink on the
thing and nothing on the memory chips.
I ran 3DMark01 and some of the tests would seemingly freeze frame,
but after that I played Half-Life 2 for an hour or so without problems
at the overclocked speeds.
I'd like a better cooling solution, however, to see if I can get it any faster
and also just so I don't fry anything since I can't afford a replacement
right now (technically, I can't afford an aftermarket cooler right now, but
that's just symantics ;) )
So, what would you guys recommend? I was thinking about the Vantec
iCEBERQ 4, which I had on the last 5200 I owned, but the ramsinks it
comes with are square and don't fit my cards ram chips correctly.
So, give me some ideas. :)
First off, that's pretty good :) . I would hack up an old CPU heatsink if you have one. Otherwise, save your cash for a video card you want, unless you think you're going to be with this one for a LONG time.
Well i have the same card, well the same gpu, mine is made by evga. Stock timings: 250/400 i found the best until performance went down was 282/527
Mr. K6: Well, I'll probably be with this card for awhile.
I'm not employed because I take care of my disabled father.
I get a check every 3 or 4 months for things I do online and
it's usually just over a hundred bucks or so.
What did you mean about the CPU heatsink? I have an old
hs/f that's not being used for anything. Were you recommending
that I just take the fan and put it on the heatsink that's on my video
card? Or did you mean something else?
For that kind of quality card I recommend the two step approach.
Step 1:
The cheaper the better!
Step 2:
Use at least two or three........... and enjoy ;) :p
kniah said:
This will probably be overkill for your card, but it's a pretty sweet deal for what you get:
http://www.svc.com/vhc-l61-u1-19.html
Shipping will probably be about 5 bucks. It comes with a fan too by the way.
Nice and cheaply priced, too. :D
I assume that wouldn't cool the ram, though, right?
I can't find decent pics of what's all included, but from what I've
seen, it doesn't look like it comes with ramsinks either.
if u want i can probly send ya a couple p2 and p3 hsk if u just pay shipping hack them up and epoxie them on thats what i did with my 5200 when i first got it
Nah. Thanks anway. But I'd rather just spend the 12 bucks or so when
I have it to get the cooler that was pointed out to me and the ramsinks
I pointed out.
