Cooling for An Amd X2
stone
What cooling do you sugest for an X2,i tried putting an xp90c on it but it kept crashing. Im keeping the stock cooler that seems real nice,running at 32C at idle.
you must have put the xp-90c on wrong because that doesn't make any sense. try it again and make sure you're applying thermal paste correctly. you are using thermal paste right?
you did put a fan on the xp90c RIGHT??? lol... yah u mounted it wrong.... and 32idle on stock is great.... you dont need any better HSF unless ur overclocking.. but since u have an xp90c already.. might as well use it.,.
XP90C can passively cool my X2 (for a little while, anyway. I didnt do any longterm testing), so you probably mounted it wrong.
