Cooling for a antec aria
well, AFAIK neither of those will fit an aria. the power supply overhangs the cpu socket on most matx boards (if not on all of them) so a stock amd heatsink is about the tallest thing you can fit under there (well, an amp heatsink plus an 80mmx25mm fan on the bracket they so nicely mounted on the psu)
my recommendation would be the solid copper Dynatron heatsink on newegg, with your choice of 80mm fans.
assuming they do fit, the zalman is better.
