cooling for a amd mobile
arock1_3
I'm getting a AMD 45 Watt Mobile Athlon XP 2400+, 266 FSB, 512K Cache, socket A. What heatsink and fan would you recommend the most?and by the way I'm on a budget :D
Hellooooo. Is this a dumb question? If it is please take me out of my misery :(
I apologize for that :) I checked the link that you provided and they don't have anything for this processor what else would you recommend.
Wolf-R1 said:
Dude...15 minutes isn't always enough time for people to answer you. Patience Grasshopper.
Try this place:
Heatsink Factory
just FYI young grasshopper. The mobile is no different from a regular "barton" processor other than in the respect of power consumption. So, in short ANY heatsink that will work for a barton CPU will work for a mobile CPU, so long as the heatsink will fit on the motherboard being used. :D
