TSS Modder
- Jun 29, 2004
just to save time, i thought that id condense a few cooling questions i have into one thread.
1) CPU cooler:
the Thermalright XP-90 seems like my best choice. my question is should i buy a XP-90 or XP-90C? ill be buying a Venice 3200+, so ill be OCing it relatively high. would the extra 20$, weight, and copper be worth it?
if i was to buy the XP-90C, would i be able to undervolt the fan and still maintain reasonable temps? ill most likely being buying a Fanbus, so if i kept the CPU fan pretty low i should still get fairly low temps.
what about Arctic Cooling CPU coolers? i havent heard about any of these from anybody. i just stumbled on them while checking out GPU coolers. the Freezer 64 looks pretty nice: http://www.arctic-cooling.com/cpu2.php?idx=10&data=2&disc=
anybody have any takes on this?
and what about the Zalman CNPS-7700 Cu? http://www.zalmanusa.com/usa/product/view.asp?idx=145&code=005
2) GPU cooler:
Zalman VF-700 Cu. its quiet, its copper, and its from Zalman: http://www.zalmanusa.com/usa/product/view.asp?idx=149&code=013
Arctic Cooling NV Silencer 5 Rev.2: http://www.arctic-cooling.com/vga2.php?idx=40
my main concern for the GPU is its noise moreso than its heat. ill be looking at getting a 6800GT. i need a GPU cooler that can keep things relatively cool w/o much noise. the GPU will obviously be OCed. i also need the GPU coolers to work on 2 cards in SLI. i wont be starting out w/ SLI, but it will definately be a future upgrade, so i need a GPU cooler than will fit in a SLI setup.
3) RAM
the RAM i will most likely be buying will have heatspreaders and will be OCed, most likely w/ the voltage knocked up. will a XP-90 w/ fan be able to blow air on the RAM, or will dedicated cooling be necessary?
4) Fans
what brand fans should i buy? the case that i will buy (unknown) will be using 120mm fans, hopefully. at least one in teh front and back. possible one up top. i need very quiet fans. again, ill probably be using a Fanbus, so they will be undervolted, but i need them quiet out of the box.
5) Fanbus
which Fanbus should i buy? need some recommendations here, since i dont know which ones i should look into. it needs to control at least 4 fans. 5 fans would be preferable, but i dont need a lot of excess controllers. if one has a switch for CCFLs, thatd also be great for when i want to turn them off.
i dont care too much whether the Fanbus uses knobs or switches to control voltages. id have more control w/ knobs, but a simple flick would turn a fan from 12v to 7v (or 5v) to off, which might be convenient. w/e. you guys recommend to me what your preferable Fanbuses are.
1) CPU cooler:
2) GPU cooler:
3) RAM
4) Fans
5) Fanbus
