Hi folks!
I'm new to this forum as well as to computer hardware in general. Therefore, it'd be good if your responses can be as "layman" as possible.
I just upgraded my computer to an Intel P4 3.6GHz processor and Intel D915GAV motherboard. Now, my problem is HEAT! Also, nothing is being overclocked!
My setup uses the heat-sink and fan that, I assume, came with the processor (got the machine assembled at a store). The Intel software claims that the CPU area temperature is between 60 deg C - 65 deg C. This, I believe, is too much. I've heard that optimal temperature should be < 50C.
The Casing is such that there's a funnel that conducts air from a cut-out on one side directly to the processor fan. When I place my hand near the intake, I can feel the air being sucked in. But, inspite of this, the temperature is high.
So, my question is: how can I effectively cool the system WITHOUT taking the water-cooling route? Since I'm not too hardware savvy, WC is out of the question.
What are my other options? In case of products, please give brand names and on-line retailers where I might purchase those products.
Thank you very much for any help extended.
