Cooling CPU in MATX?
stop45
Matx CPU cooling? I am about to order an X2 4200 with a ball blue cooler, will this fit in a micro atx case or di I need a special fan?
a ball blue cooler?? i dont get that
btw what does this in ur sig mean : OCZ 2ghz 3200 ?
it depends on the case you put it in.... what are the dimentions of your hsf (a link for it would help)
pstang,
I am sorry, I guess specifics would help. The case is an Aspire Qpack with the Asus A8V-MX , AMD Athalon 64 939 x2 4200 with a Zalman CNPS7000 "Ball Blue" cooling fan. I am just concerned about space, I am building a few new workstations for my studio.
Thx in advance for the input.
As for you w00ty, OCZ Platinum 2x1GB DDR400 Dual Channel Kit . Please excuse my GB-ghz typo, I should be banned.LOL :eek:
yeah np at all, i have the Zalman 7700Cu, which is the 120mm version of the one ur getting and still fit perfectly.
by any chance do you know if that would fit on the tforce in a qpack? i have the 7000, and its kind of tight.
