Cliffs for how we got here:
bought this case a few years ago: http://www.newegg.com/Product/Product.aspx?Item=N82E16811196014
Bought swiftech apex watercooling, got the dual 120 rad hanging off the back, rig in the sig cooled but had an 8800GT in the loop as well.
Everything was great till the 8800GT died and i hadn't registered it so evga said screw you.
bought 5770, the reverse atx on my case now pwns me cause half the heat is collecting in the top of the case and i've got no blowhole.
5770 isn't enough for bad company 2, have 5870 incoming with the ref cooler, so i'm going to have even MORE heat collecting in the top.
Last issue is that the pod that holds the usb on top is JUST far enough back that a 120mm fan won't fit behind it.
Solutions:
1, add an antec dbl slot fan and hope it can dump enough out the back.
cheapest solution, no cutting involved.
2. buy/borrow dremel, remove top usb pod, cut 120mm fan hole, install 120mm blowhole.
2nd cheapest, loss of usb but mitigated by use of usb hub, best option to keep 5870 aircooled
3. drop my currently unused mcw60 onto the 5870 and buy one of the passive sinks for the rest of the card. Swap dbl rad for a triple to hang off the back.
more quiet solution, but requires complete replumb of water setup and now the rad is HUGE and is taller than the back of the case.
4. combo of 2 and 3. remove usb, add 120mm blowhole. Install mcw60 and passive sink for 5870, add 120mm rad to top blowhole to help dissipate the extra heat in loop from 5870.
Probly the most work of all of em, probably equal in terms of price to 3.
What do you guys think would be best? I'm leaning toward option 1 to start with, and if that doesn't cut it go to something more drastic like option 3 or 4.
Solutions:
