I'm building a z77/2500k setup with dual SLI 480... all under water. Will be using the switch 810 case. The 480s have DD full water blocks. My current plan is the:
XSPC Raystorm Extreme EX or RX 240 kit
plus
EX420 radiator
Plan to go from pump/res combo to cpu to 420 rad to gpu to gpu to 240 and back...
EX vs RX on 240 kit is $40 difference
Kit + 420 rad is ~$315 with the two ex radiators...
Any suggestions on changes or alternatives? I'd like the most cooling possible without spending anymore money than the $300-350 amount.
plus
EX420 radiator
