Dark_Legacy
- Dec 7, 2006
Currently Installed
CPU: Intel E6600
Clock Rate: 3.0GHz
Voltage: 1.288V
Model: Revision B2, Stepping 6
FSB: 1334 MHz
Bus: 333 MHz
CPU currently underclocked to 30C because of dust that clogged up CPU cooler. Unstable @ 3.2GHz with dust.
Cooler: Cooler Master UFO Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103001
Thermal Paste: Arctic Silver 5
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
Case Fans:
3x Antec TriCool 120mm
Back: Intake, [BROKEN].
Top: Exhaust [Functional]
Front: Intake (Pointed towards GPU with dust grill) [Functional]
Case: Antec P180
Motherboard: eVGA680i
Changes
Budget: $220
* New 3x 120mm Fans
* New CPU Cooler
Cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
Fans: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2000110573+1372726538&name=120mm
Supreme Fans: http://www.newegg.com/Product/Produ...2000110573+1372726538+1373026503&name=>80+CFM (Apparently, these are very noisy. People are comparing the sound to a Harrier taking off. I sleep in the same room as the machine.)
Addendum
You guys have given me absolutely solid advice for years, and now one of my fans has died; and after a recent system upgrade I want to overclock my CPU further.
What do you guys recommend in terms of CPU Coolers and 120mm fans?
(Remember, the size of the P180.)
Thanks in advance.
CPU: Intel E6600
Clock Rate: 3.0GHz
Voltage: 1.288V
FSB: 1334 MHz
Bus: 333 MHz
Case Fans:
Case: Antec P180
Changes
Budget: $220
* New 3x 120mm Fans
* New CPU Cooler
Addendum
Thanks in advance.
