Cooling a P4 in a Lunchbox Chassis
Bankie
Hey guys,
I'm having problems keeping a P4 cool in a Lunchbox Chassis. Here are the specs:
Hardware:
Prism N9 Lunchbox Chassis
Intel P4 3.2C
Intel D865PERL Motherboard
4GB Corsair DDR
ATI Radeon 7000
2x 200GB WD SATA drives (1 in a removable 5 1/4 bay)
1 DVD Burner
1 Floppy drive
Cooling:
Stock P4 fan (blows down onto the heatsink)
Stock PS fan (blows out of the case)
1/2 height 80mm fan over vid card (blows out through a blow-hole)
80mm fan (sucks air into the case)
A slot fan thing (positioned above the CPU HSF and Chipset HS)
The motherboard mounts upside down in this chassis so the CPU is at the bottom of the case. The power supply mounts over top of the CPU and leaves about 1mm of space between itself and the CPU HSF. Here's a link to the chassis.
I'm using 3dmark01 in a continuous loop to stress test the system. Usually the system will start to overheat at 60-70 tests (about 5 full runs). Intel Active Monitor complains about System Zone 1 being the culprit. According to Intel, System Zone 1 is located near the CPU.
I'm thinking that a HSF that blows air up and across the heatsink into the slot fan may alleviate the problem. Any thoughts/ideas?
