Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
As long as the mounting holes have the same orientation, any standard 4850-compatible cooler will fit. Look up the mounting specs for the 4850 and measure your card against them. If they're the same, you'll be fine with any normal aftermarket HSF.
