Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Is mine! Thank you - just got here. WHILLS303 is my wife Marilyn's eBay ID. I tried for a thousand years to get jhanlon303 over here - It hates me.
In the end there can be only one!
john
When Cheapskate bench tested the blocks after manufacture they cooled his board (same one) to 1 degree above room temperature with a single 80mm radiator. I'm using a dual 40mm radiator and don't expect that good of results. Besides, at 1.5Ghz it can be run fanless in a large enough enclosure.
