micro review of the accelero twin turbo II.
have a evga vanilla gtx 670 the short pcb one. the stock heatsink and fan never gave me a problem but wanted to try the accelero.
install was straightforward. instead of using the accelero mix your own glue crap i re-used the thermal sticky pad on the orig heatsink and applied the smaller accelero heatsinks to the vrms. left the memory alone as i dont think they get that hot and they are right under the dual fans of the heatsink anyway.
stock temps were 34 idle and 72 under load
with accelero my idle is now 28 and running kombuster the highest it got was 59.
this is all with the accelero fan running at 75%
sound wise it is undetectable over my case fans i simply cannot hear it where i could hear the stock fan ramp up very easily. overall i am very pleased with this heatsink.
