Ok, I've got a DVR that records my security cameras. The damn hard drive started getting errors and I replaced it. Now I'm erasing it with killdisk and boy it is HOT! When I get the replacement, I thought about adding it to the system but the heat buildup scares me and it could be the reason the first one failed so now I'll have 2 HDs.
The hard drives mount to the bottom of the DVR case so cooling is a real problem not to mention it only has one tiny 40mm fan to cool everything blowing out from the side. The only clearance is at the top
I'm looking for cooling solutions including what I think will have to be cutting the case on the roof to bring in some fresh air but I can only hook up 2 fans so I'm thinking 2 120s but where to place them and should they both blow in or one in one out, not sure.
Any ideas would be appreciated. Here is the diagram. I know I know. It is awesome work. No I don't offer classes.
