These are idle temps...
My E4300 (@2.4GHz currently) idles 24 or less. On the stock cooler. In the Lanbox.
On the contrary, yes it does. And that's the CPU temperature. The core measurements are lower... for whatever reason.no, it doesn't
Have you SEEN a Gemeni II? Those things are HUGE. It fits two 120's.
ok if thats the case then its probably accurate. if you are like any other normal computer user, then the temps are inaccurate.It's pretty damn cold... it's near 5-6c outside with the window open all the way, computer is next to the window...
I have to wear a hoodie and have blankets by my feet, otherwise it gets too cold for my fingers to even type
And wouldn't .17 c/w for a 65w proc be 11c? Or do I not understand the ratio... Maybe the other core is more accurate? Speedfan doesn't read that one... unless it has a different label than Core...
Hmmm Coretemp shows the other core at 10c more than the other one... it's at 18c and 28c for the other core right now...
First core is my CPU, 2nd is GPU... Speedfan only gets 1 core for some reason
http://www.lousyhero.com/blaze/13c.jpg
I see no reason for a watercooling setup, when a $20 Air heatsink does that.![]()
I don't know if this is off topic or not, because adding and subtracting 15c was mentioned. If it is I apologize.
My question is : if your cpu is a Tjunction 100c and you're using, say, Core Temp 0.94 and it says 85c for the Tjunction do you add 15c or subtract 15c to get a reference cpu temp? (common sense is adding, no cpu , even one in a artic snow storm, has an ambient temp that would show a negative cpu temp with simple air cooling) I say reference temp because I've read many times there is no 100% accurate cpu temperature software
Edit: Man, I just saw the picture of the Gemin11 in the previous post. It even looks cool especially with 2x 120mm fans (looks like I'm into echoing, the person before me said about the same thing)
I know with my E6600 in my Air box I get 22C on both cores with the top off and 2c more with the top put back on. Im sure if I lapped the cpu and cooler it might get a little lower.
Is anyone running cooler than 22 with just air cooling?
You can't get colder than your ambient room temp on air cooling.
Second, to get a true idea of temps, start at ambient, take the thermal resistance by the wattage of your CPU and add that to the ambient. That's what your cpu should be around in temp.
The ambient in my room is around 26C, I have a fully loaded CPU with around 160W of heat to dissipate, My thermalright ultra extreme is around the 0.2C/W rating (thermalright doesn't advertise it's resistance, but given it's performance it's close to there or lower). That gives me around 32C which totals 58C...
low and behold, Everest and Asus Probe II both indicate temps of the core in that range. If you grab a thermal infrared probe and try to get a reading around the heatsink base you will find it to be much higher than room ambient for sure.
