Coolermaster vs lian li
Rof_lmao
Which Company do you gusy think is THE BEST in terms of looks, moddibility, size, etc.
To narrow it down for you guys. Coolermaster Praetorian (bah, funky name) or the lian li 75 series.. Basically, gonna add watercooling, custom paintjob, lighting, etc. Hopefully will go to lans with it.
Thx in advance :D
Both are well built and have their own advantages, but LL's, being in most cases the most simple and clean case, are a modder's dream ;)
i am in love with the atc 111 or whatever, the one that they soped making, looks like the preatorian but has the front cover
i love my 65 tho
i'd say cm
I have a Lian Li PC65B and its great. I never had a coolermaster before though so I cant say which is better. I can say that I would definately get another Lian Li though
I hav LL pc-60 w/o the windoze. The freaking thing is awesome, I slapped 5x40gig HD in that HD tray and remoded most of stock 80mm fans for better intake and exhuast. Im thinking putting a 120mm blow hole in it. But LL's is great, I never dealt with CM before, so I can't really say anything yo :D
I have had 13 Lian Li cases and 6 Coolermaster cases, and I still prefer Lian Li....
The finesse is simply superior to Coolermaster and there is a quality difference between the 2.
Klync, how did you go about modding the 80mm fans exactly?
I recently bought a LL PC6077, along with an add on EX-23 (spare HDD cage that mounts in 2 5.25" drive bays). I put the extra rack in the 3rd/4th drive bays so that the intake blows straight across the CPU and out the rear exhaust (not actually installing HDD's in the spare rack).
Just curious what you've done.
since im getting lianli, this thread is now open lian li discussion :D\
"talk amoungst yourselves "
I just removed the stock 80mm Adda fans out in the front,the back and the top(thinking put a 120mm in it). Mine its hold by a 4 plastic rivits sort alike. I just a small head screw drive pry out the peg. Get a better intake(atleast 40cfm).
The 67, much like my 69, is a very easy case to mod. The stock fans are reliable but not high performing, so you can pop those out and replace them.
Next, cut out the main portion of the retarded grill on the intake than holds the mesh. This thing blocks almost all the air.
You can cut out the back exhaust grill and replace it will a much smaller chrome fan guard.
Top and side blowholes are also easily done and will help a lot.
Btw, I have that EX-23 in the same place you do and not only does it add another 80mm intake, it looks sweet too ;)
