Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
The notch I had to cut out of the top compartment / drive bay. The green dotted line is the section which was getting in my way, and the red line is the cut I made to allow this thing to fit.
________________________________________
V10 without its fans and casing. I lapped both the V10 and the processor.
I also replaced the TIM on the V10 TEC plate with OCZ Freeze, and replaced the Cooler Master fans with Scythe S-Flex G's. Yes, the original fans have red LEDs. I'm not a fan of lighting or special effects, and I like S-Flex fans quite a bit so I planned on replacing the fans anyway.
As for a small review or any general thoughts, I do enjoy the cooler. My case isn't exactly huge though, and like I said - I did have to make adjustments to get it to fit. This was my 2nd build, and my first with decent quality parts. I have a C0 chip that runs a little hot, so I'm still tempted to sell my V10 and give water cooling a try.
