Coolermaster Stacker BTX
MrDude010
Is anyone using a coolermaster stacker in BTX? I would like to see one with a windowed side panel, it was explained to me that the motherboard does not actually move to the opposing side panel, but instead inverts on the same side of the enclosure and Im confused as to how that would fit. Can anyone help me out?
some pics of how its done:
sorry, i couldn't find a pic of a window w/ btx
edit: found a better pic of mobo placement
this next image may just be reverse atx
Thanks guys, you told me what i needed to know. Im now faced with either buying a masstige or getting over it and having a window on the left. The issue for me is that my desk does not have much room on the right where the pc would go. Thanks again :(
