Coolermaster Stacker 830 lowest price
I found a deal a while back for $230, I don't think anybody else picked up on it and now its back to around $260 (Micro Center). If you are interested in the Stacker 830 I suggest you look at the Cooler Master forums because theres a lot of problems with the case. I had problems fitting my a8n32 in, the firewire/usb header cables are a bit short, you can't fit large power supplies into the case, it scratches a little easy and the side panels can sometimes be a real PITA to put on... the list goes on and on!
