Coolermaster Side Panel Q
yblocgerg
So I've got a black praetorian, and I'm looking for a side panel with a window. I've found a compatible one for wavemaster/praetorian, but have seen in some pictures that they are in fact glossy, as opposed to the praetorians brushed finish. Anybody know where to get a side panel w/ window that would perfectly match? Thanks in advance.
I have a black praetorian as well. The only windowed side panel I've found is glossy (and it's CM's panel). I bought it and it doesn't look to bad, considering I don't really look at the other side much hehehe.
But no it won't perfectly match. To do that I think you'll have to cut out the window yourself from the existing side panel.
Well I ordered this part # SPB-T01-EKA , from the pictures it *should be adonized and hairline(?) processed. Maybe I will get lucky and recieve an unpolished one:D Also got 4 of the newish rifle bearing led fans, hope they silence my system a little more, and make purty colors.
Where did you order from?
Anybody know what this "hariline process" is, I did a search and all the info I found was regarding baldness :p
