Coolermaster RC-690 Power Button
kraegor
I have a Coolermaster RC-690.. but the power button seems to be extremely cheap. After about 50 times of pushing it off and on, it seems to have collapsed upon itself, and now requires a great deal of pressure to get it to trigger.
Is this possibly just a spring issue, or something I should just pop off the front grill and pull it apart and look at?
Its a gorgeous case, and I don't wanna F with it if i don't have too.
I noticed that both the power and reset buttons are flimsy, and that really bothers me. Cooler Master does an excellent job with their cases but goes cheap on the power button... go figure.
they seem flimsy compared to other cases but they are strong enough, unless you use a hammer to turn on your PC.
the actual buttons them self are held to the case chassis by a pop in bracket...It might of just popped out?
