CoolerMaster Praetorian + tuniq tower?
bobbydole
I'm thinking of getting this case
I'm worried about 2 things:
Will an 8800GTX fit?
Will my Tuniq Tower fit?
I think the 8800GTX will fit based on the thread, but i'm worried about the tower. Is any one using a tuniq tower with this case?
Or does any one have any suggestions for a silver case, that doesn't cost much more then $100 that's got a relatively smooth front plate?
Thanks!
What kind of fans are in a praetorian?
Might want to consider the cooling capabilities for that sexy vcard you've got there :p
edit: after looking at the case I see no reason why it wouldnt fit in a praetorian..
It uses 4 80mm fans.
i'm more worried about the tower. The thing is pretty huge and it's the reason i'm looking for a new case. maybe I shouldn't worry about the tower... I remember having problems with my current case and a heatsink/fan when I upgraded my 1200 to a 2800+.. so maybe my current case is the problem..
or maybe i should just get one of those new silverstone cases :)
I got the CoolerMaster Praetorian. The damn thing didn't come with any screws and the tuniq tower does not fit in it. I guess I'm sending it back..
